Todd Turbo S
Hi All I have a 2020 Ford Raptor and I’m in the process of backing up all the original Module formats before making any changes.
I read on the Forscan Forums that you should not save/back up the “PCM Module Configuration (AS BUILT format), which is the first module on my truck. After completing all original back ups, I inadvertently back this one up. Can I simply go to my computer hard drive file and delete this, or would I need to start over? I’m assuming it’s ok to delete as I, only backing up and not trying to reinstate to the trucks computer.
Also, on the same Forscan Forum, it reads you should avoid starting the Truck while backing up the Module AS BUILT, however, my Truck prompts me to start the Truck after a while, otherwise, it completely shuts off. I had to start the struck during the back up Module process, and one time, the power completely shut off, do I need to start over?
feedback appreciated.
Todd
Todd
