Ford Raptor Rear Diff Locked Enabled
Amantux
Boston
Hi all,
It appears as though my rear differential is locked in place and on, does anyone have any words of wisdom for tricks that could unlock it?
Thanks!
Badboy4fun_wa
Seattle
Where your 4x4 knob is I believe you pull on? It automatically shuts off above 15 mph, should show if it is on with light. Other than that not sure where to look, is the dash light on for ELD?
A
Amantux
Boston
So I've pressed it in, but whenever I attempt a turn, the rear wheels spin in sync so I am assuming it is still enabled, despite there being no indicator for on the dash nor switch.
Thanks!
A
Amantux
Boston
And if it helps, I've tried turning it off at a standstill, slow creep, roll in neutral but all in 2H mode
I've also tried cycling it while standing in 4H, 4L
Dane
Littleton, CO
Does the dash indicator show it on when you purposely turn it on/pull the knob out?
AwestinTX
I had this problem a couple of years ago (on my 2013). The dealer had to replace the switch / knob. My issue was that the rear diff would lock intermittently. For a while it was solved with pressure on the knob but it finally just stayed locked. I don't remember what the cost of the repair was.
jondle
San Diego
I'd say it is a feature. A lot of people pay big money for a locked diff.
Seriously though, I've never heard of this happening. I wouldn't be surprised to find one that wouldn't lock, but full time locked is odd. It is magnetic, so the locking magnet would require power all the time. Disconnecting the wires from the diff should work unless something is physically broken in the diff, is binding up, and won't let it unlock.
Members online
93,171
56,440
jumpcutter
