Engine Cover modifications required for UPR Catch Can?
Predator
Jacksonville, FL
Has anyone been able to install the UPR Catch Can without modifying or trimming the engine cover?
I'm on the fence, as I don't want to modify the engine cover.
blk91gt
So Cal
I didn't modify the engine cover at all. A little playing around with line routing was all it took.
Predator
Predator
Jacksonville, FL
Thanks... Does the engine cover still sit flat?
I read somewhere on here that the cover, if not modified, gets all cockeyed.
1badjk
Mississippi
I installed mine and a friends. Like previously stated I just maneuvered things to fit as best as it could. Still sits a little crooked, you could probably trim it but I would worry that rubber-foam construct would fall apart if cut into
101,076
60,262
SVT_SMIT
