GEN 1 Broken front LCA mount
Mortega_69
Sedona Az
I own 2 Gen 1 raptors one is 2011 one is 2014 and one of mine we took off road ing and got it a little roughed up and bent up the front LCA mount. Here’s a picture of both of them side by side any one have a recommendation other than cutting the frame Inhalf and welding in a new frame.IMG_0051.png
M
Mortega_69
Sedona Az
sorry for not clarifying. Front lower control arm mount (Circled in red) is all bent up ignore anti sway bar I can fix that but the LCA mount is bent up picture with one circle is a good LCA mount picture with 2 circles is the bent one with a tear I can weld the tear but I’m not sure how to unbend that or cut and weld a new one I don’t even know if anyone sells them. Inside circle shows the heavy damage areaIMG_0126.jpegIMG_0125.jpeg
bigrig
San Jose, CA
I am usually all in for cutting/grinding/welding things to fix them, but given that the alignment of the LCA is directly impacted by the section that is folded, I think you may have to get some shop support with alignment equipment to pull this out correctly.
That said, KHC makes a slot delete kit which would provide you some helpful templating with what needs to be cut where and how you might want weld it back together. As you probably already guessed, going this route would provide you even less alignment adjustment (read: no LCA adjustment), so if your fix isn't square and true to the frame, you will likely have accelerated wear on your passengers side tire.
Here is a pic of the stage 2 slot delete:
aka grumpy car stereo guy
ah. i thought the thumbnail pic was the same as the full size pic. now i see it. thats going to take some work. im not sure its something you can do yourself
Gen1TillDeath
cincinnati
Yeah as mentioned, I would opt to have a frame restoration shop bend back the damaged area to ask close within spec as possible. THEN, weld in the KHC support kit. This will A: allow you to get your alignment back as close as possible. B: prevent/make this area almost bullet proof for future off-roading
Meat2022
Alabama
I own 2 Gen 1 raptors one is 2011 one is 2014 and one of mine we took off road ing and got it a little roughed up and bent up the front LCA mount. Here’s a picture of both of them side by side any one have a recommendation other than cutting the frame Inhalf and welding in a new frame.View attachment 406506
How did you do this? Hit something to hard or what?
Meat2022
Alabama
I almost rolled it well going super fast hit a big bump and the whole weight of the truck went on the front left tire well going like 35 mph not the smartest choice but it was fun
Glad you didn't roll it and everyone is ok, that looks like a rough fix, maybe it can be handled a lot easier than it seems
