Air Horn Install - Looking for switched power source under the hood
cdngunrunner
Halifax, Nova Scotia, Canada
Hi!
I'm installing an air horn (2 trumpets, air tank and compressor) in my new Screw (Lots of room behind the bumper) and I don't want the compressor or horn to run unless the ignition is on.
(The system works like this; the horns get air from the tank; the tank has a pressure switch that automatically turns on the compressor to fill it)
The Aux switches won't do the job as I never want the system manually deactivated.
I've got unswitched power and grounds and a relay tapping the factory horns to activate the air release switch on the tank; all that's left is a wire somewhere under the hood that's live when the ignition is on to tap into to run to the relay I'm using to power the compressor.
Anyone know of a wire I can use?
Thanks!
shakenbake
if you bought it from hornblasters they are pretty damn helpful. all the schematics for their kits are online as pdf files.
