2022 Idle and Throttle Noise
impaul4
TX
Looking for experience on the 2 noises I’ve encountered. I’m 99% sure the first video is the transmission whine deemed “normal.”
But the 2nd one has this chirp/ whistle. It can be replicated letting it idle and hearing it every so often. Or if you tap the gas pedal, like smack it real quick (not hold down) it does it. Some times does it on de acceleration too. Kind of sounds similar to when you first open the door with your truck and the electronics turned on . That kind of whistle click issue. I’m the video it’s about 2 seconds in and hear it once
  • IMG_8805.mov
    5 MB
  • IMG_8806.mov
    14.4 MB
awd5906
NY
The first video is definitely the transmission whine, and you’re right, it’s ‘normal’. My 2023 sounds exactly like that. Have about 2500 miles and the whine is part of the experience!
I have no idea about that second video with the chirp. I’ll park mine in the garage and give it a listen. I’ll tap the gas as well and let you know. By the way do you have the AC running? Do you have pro power? How about your mileage?
I
impaul4
TX
480 miles. It’s a 2022 built in October delivered in December and used as dealer demo.
The sound close I can replicate the chirp is whatever that “priming” noise is whenever you leave your car a while and open the door. Kind of makes a rattling noise. Kinda sounds like that and it’s coming from same engine Bay Area
Swacer_2
PA
First one is completely normal.
That second one is weird, and I've heard the same thing, but only once. It sounded to me like it was the shutters cycling up front.
I
impaul4
TX
If I’m idling and I test it out sometimes it feels like something gets stuck and it idles a little more rough and I have to rev it to get it out of that funk then it’s back to normal
awd5906
NY
I tested mine out and I did not get any sort of chirp. What sort of octane fuel are you using? Maybe see if it goes away after the next fuel up? I’ve noticed the truck is very sensitive to fuel quality.
I
impaul4
TX
I was going to try that. Honestly it’s on whatever the dealer put in last. I’m going to run 93 here in TX
I
impaul4
TX
I know the axle rust on the rear is surface and cosmetic and considered normal. but is this stuff on the frame rail concerning?
Sig Fanboy
WV
Have it undercoated by Linex. I bought a 2019 with 28K miles two months ago.
There was a receipt in the glovebox from Linex for the bed liner and undercoating. I’m very impressed with the job they did. Going to have our new 2023 Raptor done, it’s Oxford White, I’m tired of looking at the white in the rear wheel wells.
93,171
56,440
jumpcutter
