2017 Gen-2 Raptor Oil Question / Issue
Jorge
Miami
I have a question that I know you guys can help me with. I realized when I did my oil change recently at the dealer that they put in 10W-30 oil instead of the 5W-30 Synthetic-Blend they put in other times. I'm a little upset about the switch, they should have told me. My question is that on the next oil change, I do them every 5,000 miles, if I ask them to use the 5w-30 Synthetic-Blend will this affect anything in the engine that ran with 10W-30? I have 40,000 on my truck.
pat247
Oklahoma
This is the very reason that I do my own oil changes. I have had this happen at my local ford store numerous times and they always offered to correct it. Oil changes are done by the lowest paid person in the shop.
COLORAP303
COLORADO
It’s cheaper, you do it once and you can do it in 15 minutes and you can prefill your filter which you know the dealer doesn’t do.
MrLiou168
Alta Loma, CA
No issues whatsoever, but how do you know for sure they put the "wrong" oil in? Remember that there is no "technical" prerequisite to being a service writer, so most of these folks have zero clue what they're talking about. DIY this - it's a Raptor which means you don't need a jack or jackstands. And if you install a nifty drain valve next time around, it's even less than 10 minutes.
