2017 - Blown engine - 42k miles
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by AlexBuilt, Nov 10, 2019.
  1. AlexBuilt
    AlexBuilt Member
    13
    Nov 10, 2019
    Utah
    Hey fellas, new to this forum, currently have a 2017 supercab with 42k miles...
    Went to go rip the raptor around in the desert today, all of a sudden I lost all power from the petal, check engine light comes on, and motor dies.
    (I was in 8th gear doing 55-60mph cruising in Baja mode down some dirt road in 2wd) Wasn't even going hard on the truck AT ALL. Was just cruising around enjoying the nice 50 degree weather.
    Pulled over immediately as the motor had died. Light smoke coming from out of the hood so I popped it... Hotter than a meth pipe on payday. Nearly took my damn eyebrows off, kid you not. Smelt like straight burning plastic. All my gauges were FINE. No signs of overheating.
    Waited about 10 minutes, tried to start it. Just cranking over and over and over and over (VIDEO 1). One of the times it started, was idling at about 400RPMS sounding like it had a cam from another planet. Was so bad the whole truck was vibrating like hell, so I killed it.
    I tried every 10ish minutes for about an hour until finally this happened.... (Video Two BELOW)
    It began to idle correctly after the video cut out. Then truck ran perfect. Was absolutely beating it to shreds doing 80+ trying to get back to cell service. Every time I would come to a stop... Nasty metal on metal sound and big lag in power. Felt like I had to push the petal 1/3 of the way down to even get rolling to 20MPH then it would be fine.
    got it home and threw it on my lift in my garage and walked around underneath... no signs of any leakage or damage visible.
    VIDEO #1
    VIDEO #2
    Anyone else ever seen something like this with another gen 2?! Dropping it off at Ford when they open back up Tuesday as this should and will be warranty work.
    traxem likes this.
  2. f150jack
    f150jack Full Access Member
    535
    354
    Jul 18, 2018
    dallas tx
    check the oil level?
  3. AlexBuilt
    AlexBuilt Member
    13
    Nov 10, 2019
    Utah
    Oil is fine, coolant also, check both when cooled down after I got to my place.
    Also oil always changed every 5-7k miles since I bought it new.
  4. cwylie
    cwylie Full Access Member
    380
    160
    Jul 2, 2018
    Should still be under the 60k warranty. Take that thing into the dealer.
    SVTWillis and Richard Hinsley like this.
  5. Richard Hinsley
    Richard Hinsley Full Access Member
    129
    60
    Aug 18, 2019
    Alaska
    I've heard of this happening a few times from people on here. Good luck and get it to the dealer ASAP. Same situation too, not beating on it.
  6. Remoat
    Remoat FRF Supporting Member Supporting Member
    136
    66
    Aug 17, 2019
    Detroit Metro
    Plugs still where theyre supposed to be? No noises before it failed?
  7. AlexBuilt
    AlexBuilt Member
    13
    Nov 10, 2019
    Utah
    Nope. Nothing. Out of the blue! It’s at dealership now...
  8. Frank N
    Frank N FRF Addict
    1,723
    2,022
    Apr 15, 2017
    NJ and Outerbanks
    Whoa...Subscribed for the dealer findings...
  9. Hawaiian Time
    Hawaiian Time Full Access Member
    381
    114
    Dec 15, 2015
    Las Vegas, NV
    Please let us know what it was after fixed. Did you notice if you were still getting any Turbo Boost PSI on the gauge on your way home?
    Aloha, HT
  10. priest880
    priest880 Member
    24
    3
    Sep 2, 2017
    Ohh my goodness let us know what they say when it’s all done. Good luck broski
Share This Page
