2017 - Blown engine - 42k miles
AlexBuilt
Utah
Hey fellas, new to this forum, currently have a 2017 supercab with 42k miles...
Went to go rip the raptor around in the desert today, all of a sudden I lost all power from the petal, check engine light comes on, and motor dies.
(I was in 8th gear doing 55-60mph cruising in Baja mode down some dirt road in 2wd) Wasn't even going hard on the truck AT ALL. Was just cruising around enjoying the nice 50 degree weather.
Pulled over immediately as the motor had died. Light smoke coming from out of the hood so I popped it... Hotter than a **** pipe on payday. Nearly took my damn eyebrows off, kid you not. Smelt like straight burning plastic. All my gauges were FINE. No signs of overheating.
Waited about 10 minutes, tried to start it. Just cranking over and over and over and over (VIDEO 1). One of the times it started, was idling at about 400RPMS sounding like it had a cam from another planet. Was so bad the whole truck was vibrating like hell, so I killed it.
I tried every 10ish minutes for about an hour until finally this happened.... (Video Two BELOW)
It began to idle correctly after the video cut out. Then truck ran perfect. Was absolutely beating it to shreds doing 80+ trying to get back to cell service. Every time I would come to a stop... Nasty metal on metal sound and big lag in power. Felt like I had to push the petal 1/3 of the way down to even get rolling to 20MPH then it would be fine.
got it home and threw it on my lift in my garage and walked around underneath... no signs of any leakage or damage visible.
VIDEO #1
VIDEO #2
Anyone else ever seen something like this with another gen 2?! Dropping it off at Ford when they open back up Tuesday as this should and will be warranty work.
Richard Hinsley
Alaska
I've heard of this happening a few times from people on here. Good luck and get it to the dealer ASAP. Same situation too, not beating on it.
Hawaiian Time
Las Vegas, NV
Please let us know what it was after fixed. Did you notice if you were still getting any Turbo Boost PSI on the gauge on your way home?
Aloha, HT
