Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have never ran pressures that low on anything unless I was off road. Interesting setup. In no way knocking it at all I have just never tried that. Do you run with anything in your bed?
+1 on tire pressure for sure. I did a bunch of tests varying the pressure by 2 lbs each time and finally settled on 38 psi as the sweet spot that I like. Absorbs a lot of the bounce
Did you get this figured out?
As a few have mentioned, tire pressure and tire choice can make a difference. I run 35-37 psi on a 37 inch tire for comfort (D load).
If tire pressure doesn't get you there, then something is up with the shocks.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
