How To Wire Raptor AUX upfitter switches
J DAMAGE
NJ
your right i should have waited longer but i have a trip planned for this weekend so i really want this to work. I cut the relay off . Its just a male connector for my led bar and a female connector on what used to be a harness with a relay but i cut it just before it would have reached it so all I'm left with is two wires ( one attached to my pass through wires and one to the fender factory gound
The best thing to do is undo all the wiring, check the light bar directly to battery for function, like @The Macf stated, then go over the up fitter switches ( use a test light) make sure there functioning correctly, you probably will find the error while starting over.
Nignipz
alright ill let you know how it goes... but I already know the light bar works. It turns on when i turn my car/ turn the key. the problem is that the axillary switch won't turn the bar off. it will stay 100% on while the axillary switches are in the on or off position
aka grumpy car stereo guy
does the switch work with nothing connected? make sure of the oem functions first. i have heard of the aux switches not working properly
Nignipz
Not sure what you mean? When I disconnect the light bar from the up fitters , no the light is off , but the auxillary switch itself has that little orange light on the top and it as always on , just on auxiliary 1 (the only wires that I have connected under the glove compartment ) switches 2-4 are all not wired up
J DAMAGE
NJ
I'm going to see if auxiliary switch two works tonight when I get home from school
The Aux switches are live once you turn the ignition on, so if the key is in the on the switches should only light if flipped up to the on position, if your switch/switches light soon as key is on, you have a problem like @The Car Stereo Company said.
Double check every thing, disconnect the pass through wires, use a test light, and check each switch wire for correct operation, then go from there.
Nignipz
Turns out it was a bad auxiliary switch ! I connected switch two up and no problem ! Bar works perfectly
