u joint failing?
Madcowranch
Madcowranch
Genetically Modified
OK
I'll just have em include it with my monthly air dropped rations of flour, salt pork and molasses
mblgjr
The stock GM joints are glued in.
Be careful with the torch and don't go overboard, it's not too hard to explode the caps off.
Strength-wise, a sealed unit is slightly better because having the fitting creates a small weak point; as well as potential dirt intrusion (vs. sealed).
Madcowranch
Madcowranch
OK
Nope these weren't the nylon sealed u joints. Just snap rings. Put it in the vice and popped the caps right off. It was the rear that was bad. Replaced with a greasable one so it should last longer.
Thanks for everyone's help.
JP7
Likes Canadian Mudbaths
Calgary, Alberta
Mad, if the truck's lifted, watch out for clearance on the zerks when in full rotation. I learned the hard way in my first 78 Bronco after the lift, I sheared off 3 grease nipples driving 10 feet due to the angle change...
93,363
56,644
LDMiles
