To the OP- I have now been through a lot (maybe 5) IWEs over a few years of hard driving in deep sand. My most recent switch was last week after probably 12 months of regular, hard, desert driving and a few big trips. Your experience is exactly what I have gone through- the IWE fails to engage properly, and slips/clunks. Then it seems OK for a few runs, before it slips again and eventually fails completely. I think you have now got the warning that the IWE is about to give up (i.e.- you will have no 4WD). I assume that this is because the teeth are getting worn and the slippage is intermittent because the wear/damage is in one area of the ring.
Oddly, it is really hard to see the damage when you take off the old IWE, although you might pick up bits of metal in the grease. It is pretty easy to replace the IWE (even for me- and I'm an idiot) but it is easy to damage the plastic ring on the actuator if you are not careful.
NB- if you replace the IWE, make sure that you replace the actuator also… even if this seems obvious, the dealership out here (thieves, fools) failed to do so of rme the first time I had this problem.
In my experience, the biggest causes of IWE failure are:
- Applying too much power when first starting in 4WD. Much better to shift when stationary (never on the fly), wait for the system to engage fully (i give it 30 secs at least) and pull off gently. You sometimes get an innocuous engagement clunk- different in sound and feel to the IWE fail.
- Power sliding!
- Excessive lateral load (for example, when attempting self-recovery in deep sand)
- plain crappy luck. These things seem to wear out…
Good luck! The good news is that, as someone said to me, now you know what it sounds and feels like, so you won;t be guessing next time. Some sort of comfort, I guess...
