¡Más! Factory Upfitters & Easy Access wiring!!
Sitdown
Sitdown
Suburbia, IL
Yes, Looking good! let us know if you come up with a more secure relay panel bolt up solution
J DAMAGE
NJ
I think your relay panel and wiz, are pretty solid set up's , like you stated in your build, all up to how much room one has or needs for glove box clearance, but I will add to yours and wiz's set up, the more options we have the better off we are.
J DAMAGE
NJ
Completed my 8-gand relay/fuse panel, copied of (sitdowns) idea, with my added twist, my panel is a little wider than (sitdowns) being it has 8 relays, truck now has 8, but will have 12 total once the other switches get here, using the other storage pocket.
J DAMAGE
NJ
Looks really good!
Thanks Nick, fuse block should be tomorrow, then i just need to pull 8 wires through the fire wall, gonna pick up 12v power from the main feed of the in cab fuse box, adding the other switch bank will be simple being all is set-up already.
J DAMAGE
NJ
nice cant wait to see it all done!
The switches for the other dash pocket will be last, no rush, Have to fix my heated seat, screw the warranty, not worth the 40.00, to deal with half ass dealers.
93,190
56,469
ngodavid23
