Tire Weights
M64D RAPTOR
Dothan, AL
How about the Fierce Attitude 35" weights?
Never mind just found it.
Fierce Attitude MT = 35x size overall diameter 34.8 weight 62.86lbs
All The Way
Lockport, NY
Here is a new one to add to the list
TreadWright 315/70R17 GUARD DOG M/T
Weight: 70Lbs
Tread Depth: 19/32”
Meas. Rim Width: 8.5”
Tread Width: 10.3”
Rim Width Range: 8.5-10”
Max Load: 3,195 lbs
Outer Diameter: 34.7”
Max PSI: 50 psi
Section Width: 11.8”
The tires also have a "S" speed rating and have the snowflake for a winter tire
https://www.treadwright.com/p-118-315-70r17-guard-dog-m-t-b2b-d.aspx
Also $159.00 a tire...
Milez28
For the Toyo AT2's:
I don't get how the 35x12.5x17 are 70lbs and the 35x12.5x18 are 80lbs...
10 pounds heavier and it's actually less tire right?
cups
Fair Oaks, CA U.S.S.A.
Weight: 70Lbs
Tread Depth: 19/32”
Tread Width: 10.3”
Max Load: 3,195 lbs
Max PSI: 50 psi
How have these been working for you? I've avoided retreads after some experience with the many years ago.
bermise
37X13.5X20 Toyo open country MT = 94 pounds
20X9 BMF Novokane stealth wheel = 39 pounds
Total = 133 pounds per wheel/tire
Jarrett H
37x13.50/17 Toyo M/T is 93lbs.
37x12.50/17 BFG A/T is 67lbs.
13.50 vs 12.50 but that's almost 30lbs per tire difference. Have to be crazy to run a 100lb tire on these trucks.
