Plowing with a Raptor?
IRONMAN
Well-Known Member
MICHIGAN
Understood. If you make money by plowing - you need to have it insured which means having a reliable vehicle that runs in the snow (===$$$). The money earned must exceed the amount spent maintaining the ride, and that doesnt't always work out so good.
Plow trucks that last are almost always solid axle 3/4 or 1 tons. If you can pick up one cheap to take care of your plowing needs you will be better off.
As of last night, I have 12" of snow in my driveway and it don't matter, because even with the 25 degree incline, 2 s-turns, my Raptor eats it up in 2wd!
You lucky ass.lol
xsoldier
This really has nothing to do with snow plowing but i am new to this forum thing. I was just wondering if it is possible to lift a Raptor a few inches to acomidate a 37" tire, and maybe a little wider tire for stability following the lift? Thanks.
Silver Fox.
BIRDMAN
Birdministrator
Boston
Silver Fox.
according to most, 37" will rub. you can adjust the front spring perch to gain a couple inches without actually needing a lift.
here's the thread: http://www.fordraptorforum.com/f25/one-only-tire-size-thread-382/
and here's how to adjust your Shox:
http://www.fordraptorforum.com/f9/top-perch-fox-shocks-248/index3.html#post13652
BOJANGLES
Chihuahuan Desert (EPTX)
Silver Fox.
:welcome:
don't worry about being new to the forum thing, if you need help with ANYTHING, just ask any of the guys with a red or green username. We're here to help.
Mark Ducati
After reading your thread and posting my own, I decided to not buy a blade for the Raptor...
I'll probably buy a blade for my ATV instead, it will take longer but get the job done...
BUT! What about one of those "Jet Blowers"? You know, the kind they drive around the Indy/NASCAR tracks to make sure all debris is gone and the track is clean? If I can't push that snow aside, I'll MELT it! Hahaha
red jacket
roxton pond
i'm not gonna lie. i would be curious to see the Raptor plow vid.
Gonna tell you i only use it for my home and a small business, it's a Boss plow about 400 pounds, truck goes down about 1 inch, removed both skid plates thats all all the rest is original.
