New Video - (Pre-Production Prototype) SPV Parts Hitch Mount Kit for Rigid Chase Light... Give us feedback.. Who wants us to release this?
Specialtyperformanceparts
Check out the video below....
We have had great feedback so far. If you want to see this offered, let us know.
This is a variant from our hitch mount backup light kits we developed and released in 2017.
The principal is to have quick and secure access to a full size backup light, and when you want to use your hitch, just pull the plug, pull the pin and throw it in the back seat. Our Mounts are stainless steel and when used with a hitch pin/lock, they deter theft. (Nothing can prevent theft of course, but this is the most secure method.)
So for the weekend warriors, who want a quick and easy add on chase light solution. We found this to really fit the bill.
Since the Hitch wiring can give you brake, running lights and reverse, but not an on off for flashers. We are looking at an inline simple switch in the cord (Not like the video just dangling. Again, this is a test piece) that you can flip on for strobe feature for when you go make a run. Since the power will shut off to the hitch wiring when the truck is off. You still won't need to worry about forgetting to shut it off and it draining your battery.
Now, some other options we are considering are a tail light adapter module like our other harness system uses. This is more vehicle specific though vs completely universal like the 7 pin. However, it won't tell your truck it has a trailer connected.
We are also looking at a long harness as well that can run up to a switch in the front for the strobe feature as an option.
So tell us-
Do you prefer the quick plug 7 Pin Connector?
Do You Prefer a Vehicle Specific Tail Light Adapter?
Would you want a line in the front for a switch for the strobe? Or is it fine (and easier to install) if your switch for the strobe is in the rear?
Enjoy the Video-
And if you would like to see our original Reverse Hitch Light Kit with quick removal and Full Size Rigid or Baja Lights, look here-
As always, feel free to reach out to us at info @spvparts.com
Or call 317 - 934 - 6778
I like the concept. Could it be used with the four pin connector instead of seven?
I believe it could to a degree in that configuration, however, the flash/strobe uses the constant 12 v “charge” line which I don’t think the 4 pin would. So in that instance, it might be better using our tail light adapter “prep” to run a separate connection from there. Or you’d need to run a separate line to a constant from somewhere else for the flash. That might eliminate the “quick and easy” part.
Turning Blue
Northern Illinois
Thanks. I already have the Rigid SRLs with the tail light connection and long harness so I can run them as back up lights or simply to light up behind the truck when parked. Would this somehow integrate with my current setup?
swoop1156
USA
I don't ever want to run that long harness back to the front ever again Please John @Specialtyperformanceparts gimme something that can plug into the rearward harness!
Well, you’d still
Probably need a second line because one wire runs the backlights and the other runs reverse.
You could tie in the reverse, but you need a switch for strobing. That’s where we put it inline in the back there. Just a simple on off.
So my thoughts, for most people, either that 7 pin with an inline switch or a tail light adapter with an inline switch would be most prudent.
Everything would be automatic except the strobe feature which you would need to flip the switch back there for. So going back there one time to turn the switch on or off I doubt would be too much of an issue for most and definitely save on time for a quick and easy install.
John
JayRods
Manteca Ca
A option to think about in your design for the strobe feature, is a remote controlled on off switch. It might be a nice option for some that do not want to run the wires all the way up to the cab. There are several of them out there, this one might even fit inside the 2" receiver hitch. 71n-s1p-o6L._AC_SL1500_.jpg
Turning Blue
Northern Illinois
Well, you’d still
John
Thanks for all the extra info. The 7-pin connection sounds good. I'm looking forward to seeing your final product!
Turning Blue
Northern Illinois
I was wondering if plugging in to the trailer light plug will tell the truck I'm pulling a trailer and change drive mode settings or deactivate features like BLIS?
93,202
56,485
bjorn-dpc
