badm0t0rfinger
Rocket Man
The Beach
I didn't look close enough. I thought they were the reinforced and trussed ones. Thats what I was wondering the point of.
Apologies I thought you were talking about the coating. He just reinforced the spindle, which can be a weak point when you start getting really serious about your offroading.
TomDirt
Hesperia CA
The Fabrication shop also put it on a mill and drilled out the oem tapered tie rod section. The spindles now have larger 12point bolts, rated at 170K psi tensile strength. And they're only about $9 each, including the 20230125_153301.jpgcastle nut. Seems like a smart upgrade, since these oem spindles are just regular f150 units and a Gen 1 Raptor starts out at 3+ tons on 35's.
Irregular F150
its terrain good sir!
a small town in way up northeast
The Fabrication shop also put it on a mill and drilled out the oem tapered tie rod section. The spindles now have larger 12point bolts, rated at 170K psi tensile strength. And they're only about $9 each, including the View attachment 390583castle nut. Seems like a smart upgrade, since these oem spindles are just regular f150 units and a Gen 1 Raptor starts out at 3+ tons on 35's.
Hmm interesting…
Frogger22
“Not all who wander are lost” Tolkien
Rocky Mountain High
Had a super loud and annoying rattling / metal grinding noise coming from the front wheels when under acceleration…after getting the wisdom and help from @The Car Stereo Company found it to be a bad vacuum line going to the front right wheel which was half engaging the 4W drive in 2W drive and making the grinding noise. Insane to think just a little cheap vacuum hose stopped that gross noise! Life is better! Now I just have to deal with the front Diff leaking….but shout out to Car Stereo! He is the OG!
93,202
56,485
bjorn-dpc
