GEN 2 Admins delete thread please
908jeff
That's just water vapor condensing in the exhaust, normal. I hate to say it, but having the misfire issue occur right after the tune was installed is pretty coincidental...
Hey it is what it is right, can’t change anything now. I actually bought colder Ford performance plugs to switch them out because everything I read said I’d would need new plugs and they need to be gapped at .026-.028. I might still try and put one of the new plugs in cylinder 5 just to double check the shop gapped it right but leave them at the .030 they come at since I uninstalled the access port. All I can do is wait and hope/pray it’s just the injector. I’ve read nothing but good things about goose tune so figured I’d give it a try but I should of known better, I always have sh*t luck and random things happen to me. Thanks again for commenting, I appreciate it.
908jeff
@FordTechOne should I try and replace the boot on the coil when I switch the plug in cylinder 5 later today? Could you tell me if I should buy Motorcraft WR-6135 boot or is it a different part number for the boot? Or don't even bother with it?
908jeff
908jeff
Thats only part of the boot…you want Motorcraft WR6151 per the Ford Parts Catalog.
Thanks for the park number. I got my fat arse up on the engine and was able to pull the “new” plug. And here’s what it already looks like. Smells like gas/oil not really sure which is smells more like ha
1BAD454SSv2
HELL I ZONA
Man that plug , that's some ugly mustard
nikhsub1
Los Angeles
