Ok, broke front sway bar end link on White Rim Trail in Moab and need to replace. The diagram in Ford’s manual shows incorrect part and #. It shows and denotes a part that is a straight shaft with two flexing cup ends. That doesn’t work. The OEM links have the two ends perpendicular to each other at 90 degrees. Top threaded shaft goes straight up, and lower threaded shaft points to front of truck. Need help for correct part # on that. Ford dealer parts in Moab had no clue what to tell us.
Would even appreciate suggestions on an aftermarket replacement.
Thanks!
Thanks!
