Is everybody's Home-link reception/reach really bad?
Oldfart
Oldfart
works like a charm....300 yards maybe?
Do you have any LED lights near your garage door opener? LED light kill RF and can make things like garage door openers not work.
300 yards, I can't get 300 inches! The only led with power in the garage is a small nightlight about 20 feet from the opener that turns itself on when it's dark.
GordoJay
Colorado
And here I was happy with three inches ... have you tried unplugging the night light?
DarthKickA55
Tennessee
Mine does not have a great range - 30' maybe from the opener to the visor. Often I have to open the door before the garage door will open. Mine is an Overhead Door brand opener.
David1986
Clarksville, TN
Mine works great from about a house length away. Actually works better than the transmitter than cane with my garage door. My previous 18 and 13 Raptor worked great as well.
10SpdsOfFury
Jacksonville FL
One thing I did notice on mine is I have to tap it once then the garage door goes up, if I hold it down it doesn’t do anything.
Derail
Unlikely to be interference if the regular remotes work correctly. Do the regular remotes work correctly from inside the truck when the Homelink does not?
Raptor10X
Arizona
Same here but... works great during the day but at night I am almost against the door and sometimes flipping the visor down to get it to work. Glad I’m not the only one. Thought it was an opener issue.
NHDude4
Southwest, NH
Yep mine sucks. Some days (almost seems weather dependent) it works from 100ft. Other days it won't work until I'm stopped with the bumper 5ft from the garage door. I also find that moving the visor vertical seems to help a little. Probably something to do with the Homelink antenna orientation.
