JoeCaMotto
Chitown
I want to give a shout out to my guy Kamil for a awesome job on my truck. I use my truck for work I have a flooring company so I use it to carry flooring, plywood etc.
And It stays out side not a garage queen. He’s price is very reasonable also.
07_S3VA
Picked my truck up from service at dealership. Now I have heating/cooled seats and rear defroster that work properly again. The fan for the cooled seats is much louder now. 3 days in Ford Edge loaner was rough.
Dale K
Tualatin, Oregon
Ohhhhhh, changed a bunch of settings with Forscan, ran a downframe harness with 6 spares, wired in my canopy for brake lights-12vdc power-canopy door lock actuator....little stuffs like that
nikhsub1
Los Angeles
I attempted to install my new RPG shackles but no joy. I could not get the upper bolt out that holds the shackle to the spring. The frame is in the way no matter how high or how drooped I made the rear end. While I was in there I did some rust removal and some lubrication.
Johnfaeglasgow
Kansas
What leafs are you running? I have extended RPG shackles coming this week for my icons and was hoping it would be a quick job [emoji51]
Oldfart
This thread has reached a all time high. Rubber bed mats, and cup holder discussion!!! Anybody doing any real mods these days?
I am!! I just mounted a couple of these awesome bud vases in my truck! I can send you the link if you want. I do want to warn you though, it doesn't come with the pretty flower.
zombiekiller
OG BooBooRunner
New Orleans
Hell I think we would all just be happy to see some updated pics of your rig!
Right now it is sitting in my garage with no front bodywork and all of the accessory wiring cut and hanging.
I'm in the midst of rewiring the entire truck.
Once I'm done with the rewire (converting to all Switchpros), Then I'll fit the new front glass that I've been staring at for 4 months, do a little fiberglass work on the bedsides, and replace the passenger doors.
After that it needs a new headgasket.
Then it will get wrapped.
Then i'll drag it out to cali to have the cage and tin work done.
The rest of the stuff that I need to do is maintenance and/or fixing broken stuff. ( like the lower steering shaft, removing, sanding and repainting different parts, replacing hardware, etc etc. I need to get the truck back to the shop to have the guys change a few things too).
I've been hammering on the truck for a couple of years now and its time to tear her down a bit and make her pretty again.
Probably won't see any prolific pics as shell be in pieces for a couple of months.
