Oldfart
You would smell it if dripping on hot surface. it could simply be poor bleeding from factory and air has worked its way out. Did it come with the yellow factory fill?
So I had this issue with my 2018. I could faintly smell coolant once the engine was warm. When I took it to the dealership they did a pressure test and said everything was fine. I continue to smell coolant and saw my coolant level slowly dropping. After digging around I saw some drops of coolant weeping from the water pump. I took it backTo the dealership and they found that there was a casting issue from the manufacture of the water pump and of the thermostat housing. I had them both replaced under warranty no issue sense. I would highly suggest taking it in and have it fixed under warranty.
Yes, it has the light yellow coolant. I thought it was odd I wasn't smelling it too.
I was under it yesterday and now that it's got 400 miles on it you can see fluid on the skid plates. I think there is a very small oil leak and a slow coolant leak. What I found feels & looks like coolant with maybe a touch of oil. Maybe it's picking up crap on it's way down. It's hard to tell with the plates and it's a slow leak that's blowing around and misting so it's hard to tell the source. I'm taking it in Friday. I have it up on stands and took the wheels to the powdercoater. Hopefully have them back in a few days and get it to the dealer.
Thanks for the responses.
