GEN 2 Noise under hard acceleration
Ktwagner311
Youngstown, ohio
Has anyone else had this noise and what did you find out? Only happens under hard acceleration above 4500 on the tachometer
moonjim
Portland,or
I believe that's the wastegate linkage vibrating. You hitting a certain frequency and it does that. Just got my tsb done for the dog leg linkage fix for both sides. But could just be something loose under the truck.
Antho
have you ruled out the IWE? try in 4a vs. 2h.
Bee
Connecticut
I have the same exact noise. Same with it only being preset in 2H. I don't know what it is, but others have discussed it as engine ping/knock on this forum. I'm not entirely sure anyone has figured it out.
For me, the noise will sometimes persist momentarily when let off the accelerator...so its not pre-detonation.
I had it both before and after COBB stage 1. I ran a few logs during hard acceleration with the noise present and sent it COBB...no pre-detonation and everything logged ok.
Antho
So i replaced my 2017 with a new raptor. same specs as previous. I could not hear the noise on the new truck until i disabled the fake engine noise/noise cancellation. My consensus is that its the torque converter and is a normal sound. So my question is, Those that hear it, Did you disable the fake engine noise?
Attackpilot
It sounds a little like spark knock. Mine does it too. I’m going to replace my spark plugs and regap and see if that fixes the issue
