GEN 2 Bora Wheel Spacers Installed
Mbdurham
Georgia
Gotcha, thanks, Hopeful to mount mine this week.
Did you use Red locktite? I'm going to use blue, I can't imagine the spacers going anywhere with blue at 150 ft/lbs, but I'm worried about trying to break the red loose when it's time for brakes.
Yep I used red 272 high temp. Me either but I am going to pull the wheels off again this week and re-torque as recommended. Don’t want to take any chances
Halo Raptor
Monrovia, CA
Does anyone know if the non-beadlock and beadlock wheels have the same back spacing. I have the nons and they say they are 34mm back spacing. What are the beadlocks?
Pacific Wheel
Reno, NV
They're all 17x8.5 +34 from 2010 to current. Beadlock capable or non beadlock
Jeff-Ohio
Cincinnati
For those thinking about getting BORA spacers, I added 1.5" BORA spacers to my 2017 (all four wheels) and had to trim the really soft plastic in the wheel wells up front. It was extremely easy to do and probably took about five minutes per side, but I was definitely rubbing at full wheel lock.
GR8Ride
Upstate New York
1.5” I would say because when I installed the 1.25 the hit slightly
I followed your process and drilled my ‘19 Beadlocks to fit the 1.25 Bora’s as well. I am so thankful that you shared the idea as it’s a great option.
I think as the spacer gets wider there is less lug to hit the wheel so at 1.5” the lugs should need no trimming where as the 1.25” need little and 1” will need more.
BTW- your build is looking amazing!
HAPPILY EVER RAPTOR
