siooss
Florida
I added a 1/3 quart, no issues
But what is that CAI you have? At first I thought the thing was duct tape.
CAI is a Volant, wrapped with https://www.heatshieldproducts.com/cold-intake-shield, put adhesive backed shielding on box, with headers, figured every degree cooler air helps, have air scoop as well. Added heat reflecting material on fire wall, fuel rail, sleeves for spark plug wires, A/C lines and the like.
Chiefapple
Milwaukee, WI
Cleaned the throttle body and replaced the valve.
renegadeagle
Puerto Rico
Did another "me too" upgrade, swapped out to the heavy duty transmission cooler, easy enough. Recommend not adding transmission fluid to the cooler as recommended. I added the recommended amount by Forge Off Road and resulted in overfull condition with transmission fluid that came pouring out when removed the plug/dipstick. Had to remove some fluid, oh well. Easy enough to add fluid through the plug/dipstick if needed.
Where did you purchase your heavy duty transmission cooler??
Best regards
93,202
56,485
bjorn-dpc
