Forscan changes - tweak your truck
PupDawg
Cheyenne, WY
Has anyone tried successfully to get the Auto Relock enable to work on their truck? I hate worrying over whether I have locked my truck...
Also curious about the interior alarm disable and disabling the ignition shut off, we travel frequently and keep our dogs in the truck for short stops, would like to be able to keep the truck running when we stop to eat or even leave the sunroof open and shut the truck off without having to remember to disable interior alarm. I have seen the changes necessary but wanted to know if they are actually working correctly.
Wfo
Syracuse
On my 2018, the lowest it would accept and show as “specified” is 25. You just convert code line to the hexadecimal equivalent. 695e559490145f4d07a0684043e0de04.jpg3316fc5ecc2551cda664765d04d5dee2.jpg
Thank you for the response! Did you try to go lower than 25? I’m on 37s with method beadlocks so I can go low.
rtmozingo
North Texas
The setting is for what the placard states - ie what on-road cold psi you run. Should be in the ballpark of 30-36psi. The low indicator comes on at a PSI below that. For a setting of 38 that seemed to be around 28-30 psi in my truck, so perhaps 10 lower than setting?
Wfo
Syracuse
Sure would like a confirmation on this theory.
93,202
56,485
bjorn-dpc
