GEN 2 Rear Park Aid Volume adjustment?
Highpox1
Houston
(2019) Is there a way to tone down the volume level of the rear park aid beeper? That dang this is LOUD. If I am trying to back into a tighter space, such that it takes a minute, it gets very annoying, especially if there are folks in the back seat. They have all complained it's too loud. Yes I could shut it off using the steering wheel controls, but wanted to see if there is a way to lower the volume. If I knew where the speaker was, I could add insulation over the unit...thx.
EricM
OHIO
Not 100% sure on the Gen 2 trucks, but it's most likely fed into the audio system over the CAN bus, then played right through the speakers. It pretty much has to be part of that system to be able to lower the audio level when it activates. Unless it's accessible through Forscan, it's probably a fixed level as well. Just use the steering wheel control and turn it off, you know there's something back there once it activates- you really don't need to hear 100 more beeps as you get closer to it.
Spectragod
Dayton Ohio
I programmed mine to only play through the cluster peizo. ForScan is your friend.
goblues38
STL
well...with an aftermarket stereo and the NAV TV unit...you can configure what volume and what speaker alerts play from.
Spectragod
Dayton Ohio
MEATSWORD
Arizona
I'll have to dig my notes out and go through them, I did it on both my '15 and my '18 raptor.
Thanks!
I looked at the spreadsheet again and found something that looked promising but don't want to brick the truck or double the volume by accident lol
93,202
56,485
bjorn-dpc
