GEN 2 20” Wheel Question
Nick@Apollo-Optics
Nick is the man!!! He got me my wheels. I have trail graps on mine. 35x12.50x20
At full lock I get a small amount of rubbing. Nick can this cause a problem if I don’t do anything about it? Love the wheels. Thanks
Appreciate the kind words! And glad we could help get you setup! The minor rubbing isn't a big deal as long as it's at parking lot speeds, which it usually is at full lock. I wouldn't worry much about it, however, if it did bug you enough, a little fender trimming would solve the problem.
Does anyone know which wheels are on this truck?
Those are Fuel Rampage 2-piece wheels. Pictured looks to be the 22" version.
ameration
Ohio
Thanks Nick.
Anyone running the 35x12.5x20 with a +12mm off set in KO2’s or Nitto Ridge Grapplers without leveling that can help answer if you have rubbing at full lock??
Thanks!!
I have the VR601’s with 35x12.50R20 Mastercraft Courser MXT’s and had no rub at stock height.
Erjdrvr
Indy
Lead foot grey and it is not available anymore. Wheels are 1.3 inches pushed out.
I thought 601's & 602's only would stick out another 0.91" over the stock offset?
Sent from my SM-N960U using Tapatalk
Raptor911
Ashburn, VA
34mm (OEM offset) - 12mm (601s and 602s offset) = 22mm or 0.866142 inches.
601s and 602s is a 9inch wide wheel which means .25 inches will be on either side. So .25" + 0.866142" = 1.116
so the edge of the wheel will be pushed out 1.116" when compared to oem wheel.
I was wrong about 1.3" sorry.
Aventador22
Anyone have experience regarding the Nitto RG 325/60/20 vs 35/12.5/20 with the VenomRex 601? Trying to figure out which ones to go with that will give it an aggressive poke without too much rubbing.
500mag
Georgia
