Solboricua18
- Joined
- Jun 13, 2017
- Posts
- 82
- Reaction score
- 4
Burnouts?? I cant phantom the idea...tires are expensive enough.
Agree works every time.Ok turn off traction control.
Put car in 1 or 2 gear. Lightly put your foot on brake just enough so that it is engaged and you are not moving. Slowly press the gas an hold the brake enough so you are not moving but not killing the brake.
Keep applying the gas more and more until you start to burnout.
That's my way.
Also put in Baja mode and then switch it back to 2wd. Best way todo doughnutsAgree works every time.
Agreed, the 2010's , hold traction control for 10 secs, 1st gear and let 'er rip tater chip!I can do a burn out no problem with my 5.4, a 6.2 should be even easier.
