- Joined
- Dec 16, 2016
- Posts
- 16,303
- Reaction score
- 24,057
If it’s a con rod bearing, that’s assembly or a defective bearing. I’ve spun 2, one in my bored/stroked ZX11 drag bike, the other in a <gasp> v8.
If all OP says is true, actually, even if it’s just close to true, I’d agree to pay for the teardown but I’d want someone taking a look at the cause. I’d like to know how an ecu tune fried a connecting rod bearing. If it could be reasonably articulated that a tune I had actually caused the failure, ok, fair point. But, having a tune doesn’t grant carte blanch for a dealer to assert or a manufacturer to enforce a blanket warranty denial on unaffected parts. burnt valve, hole in the piston from detonation, rod through the block etc because of the tune - yep, I get that. Unfortunately, I’ve been down this path before. It was 6 weeks to resolve, and I eventually prevailed but I got hooked for the tear down money. In my case corporate heads prevailed before court. My mods were just bolt on stuff - ignition, pulleys, MAS, filter & intake, but of course they made an issue of it. None if had anything to do with the failed timing chain tensioner ( on a v8 also ).
This dealer’s not doing you any favors here, frankly, they’re not being an honest broker either. I would push them for a cause of the failure, and make it clear if it’s not something supported by evidence the tune caused the problem, Ford will need to honor its warranty.
