Diff Whine & Fluid Change
sfadchi
Wellington, FL
Pretty sure I may have gotten muddy water in my rear diff over the weekend. I’m getting a slight whine between 45-55mph. Does the rear diff use RTV or does it have a reusable gasket?
TK85
I just changed the diff cover on mine the other day and there was a lot of rtv I had to scrape off. New gasket and new rtv I would suggest.
TK85
Sounds like a good time for a Ford Performance diff cover to me.
That’s the one I just put on. Looks and feels great. I didn’t like the gasket that comes with it so I got the lube locker gasket which is much better and no rtv needed
sfadchi
sfadchi
Wellington, FL
I just ordered up a lube locker. It will be here Saturday. Hopefully I didn’t do any permanent damage. All of my Jeeps had a little one way value on the breathers. Shocked when I saw this one.
Spartan1
Mars
https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=SAE+75W-85+Premium+Synthetic+Hypoid+Gear+Lubricant&category=Transaxle Fluid
Note: For a complete drain and refill, limited-slip axles require addition of Friction Modifier, Part Number XL-3 meeting Ford specification EST-M2C118-A. Refer to Workshop Manual or Owner’s Guide. For a complete drain and refill, Torque Vectoring RDU requires addition of Torque Vectoring RDU Gear Oil Additive, Number XL-19
I was going to use the Motorcraft differential fluid but I am not sure what the above means. From what I understand, some differential fluids have friction modifier already in the fluid but the motorcraft does not. I am not sure if I need this friction modifier or not. Does anyone know if I have a "limited slip axle" on my 2017?
It sounds like I do not need torque vectoring RDU gear oil additive like a focus RS would require.
https://driving.ca/ford/f-150/revie...-a-tale-of-two-very-different-off-road-heroes
It also sounds like the front differential is a limited slip in the raptor but maybe the rear is not?
https://www.cjponyparts.com/catalogsearch/result/?q=2017+ford+limited+slip+differential
sobiloff
Reno, NV (USA)
The rear diff is an electronic limited slip (AdvanceTrac). (Front is a Torsen.) So, you just need
Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant or equivalent, no friction modifier required.
