Stock Rake
  • Start date
Can someone tell me what the stock rake is?
I never took measurements when I first got my truck. Measuring from the ground to the center fender lip.
My front is at 41" and rear at 44.5"
So a 3.5" rake right now.
I am not stock but curious how far off I am? I am at mid-perch and have WSI HD springs, from what I searched here, those are 3+.
Bed weight: (two spares - under and in bed), bed cage, jack and 24g action packer.
LekRap
Corona, CA
Haha, yeah, I think your going to have a hard time finding someone on here with stock height. I would imagine that the stock rake is very similar to yours now. Seems like you gained in inch in the rear with your hd/+3's and should have gained 1.5" with your mid perch. I thought I was higher in the front at mid perch...closer to 42", but that's splitting hairs. Basically, I think stock rake is very similar to what you have going on now, you're just basically an inch higher front and back. That's my guess
Meyercord
Dallas, Tx -> Houston, Tx
With the weight you have in the bed you're the same as I was with deaver +2s and no weight in the bed.
I'm currently at 41.5/ 43.5 with mid perch, deaver +2s and a 1" drop shackle.
LekRap
Corona, CA
I was just looking at some of your other posts earlier this morning. Seems to me like your Deavers are sitting higher than most +2's. Are you sure that yours are +2's and not +3's?
I'm looking at getting Deavers right now and debating between +2's and maybe just running a drop shackle or getting +1's.
Meyercord
Multiple companies would've had to of really missed up for me to end up with +3s.
LekRap
Corona, CA
So did you have the Deavers on without the shackles? Was it sitting at 44.5" that way? I only ask because I've seen the design of the synergy and I know it's different than most. Curious if it dropped the truck the inch it was supposed to
Meyercord
It was 44.4 the day after the springs went on.
