Windshield washer not spraying
apollo90
Ensenada, Baja California
A little stumped here. A couple weeks ago, my windshield washers stopped spraying. I could hear motor working. Intermittently, it would “ooze” or weakly dribble.
I continued to switch the washers on/off several times and it started to spray again.
It worked until today when it stopped working again. Same symptoms - motor runs - except nothing sprays.
I disconnected the tube between the reservoir and the nozzles and put an air compressor on the end, air came out the nozzles no problem. I cycled the washers once more and nothing comes out of the tube coming from reservoir. Then noticed the front camera washer does not spray either
No leaks either.
Anyone experience this before? And yes there is fluid in the reservoir
