weird shifting from 3-4 on 2013 screw
DezertRaptor
Goodyear
Hey guys my raptor just hit 4k miles and noticed its shifting kind of hard from 3 to 4th...also the gear display went away....the one that shows what gear its on
theres no CEL
ive read similar prblems from 2-3 or 4-5 but not 3-4
just pissed im already having issues with it
Quartz
Denver, CO
Is the engine cold when it is shifting hard? 5star tune can remedy this issue, not sure about warranty issues with the tune.
When you put the truck in drive or park, push the (+) button on the gear shifter and the display will come back on the LCD.
Mogo
Colorado
Actually, I believe you hit the (-) toggle on the shifter just once to see the gears displayed. If you hit it more than once, it will start to lock out your top gears.
DezertRaptor
DezertRaptor
Goodyear
It does it even when its warm and under slow acceleration...i moved it to manual to see if the gears showed but it would only show M and whatever gear its on
---------- Post added at 09:24 AM ---------- Previous post was at 09:23 AM ----------
I called stealership....im taking it in on monday
they said their transmission department is the busiest
Quartz
Denver, CO
Interesting, let us know what you find out from the stealership.
Really? The (+) button works for me, every time I push it the display turns on or off.
