Water temp send in unit placement ??
Tall Mike
Binghamton, New York
Have a 3 gauge pod for my SD and are looking for a place to mount the send in unit on a 6.2L for the Autometer water temp gauge..
Any help would be much appreciated, the SD forums weren't any help.
Mike
MTF
Celebration, Florida
Tall Mike
Tall Mike
Tall Mike
Tall Mike
The 6.2L's PCM uses Cylinder Head Temperature (CHT) Sensor instead of an Engine Coolant Temperature (ECT) sensor to calculate the coolant temperature.
So you may have to give Autometer a call and see if you can even use your gauge.
Or you can get something like this but with a higher temp sensor:
Inline Radiator Hose Temperature Switch Adapter 1 1 2" Dia 200F Temp Switch | eBay
This looks to be the best option on a Super Duty....I didn't find any ports around the thermostat housing and nothing on the radiator itself...I don't know about Raptors but the sides of the SD radiator are all plastic, I'm not exactly comfy with that....I know the 6.7L guys are having problems with radiators..
Thanks again for the info.
PropDr
Eugene, Oregon
Water temp sensors should be installed in the engines water jacked, not in the radiator or hoses.
I'm not close to my truck to check, but any plug in the block that leaks water will do; if there is none you can get a new frieze plug and have a fitting for the sensor installed in it.
An alternative would be the heater hose connection; replace it with a 'T' fitting.
SVT_4X4
Linden, MI
For the most part don't worry about the plastic radiator tanks. They have been using them now for 30 years. There are actually less issues with the new aluminum radiators with plastic tanks then the old thinner copper / brass units.
Tall Mike
Tall Mike
Based on a lot of reading on this site and a Super Duty site my truck *should* have come with a block heater but didn't..
I looked in the spot where I think the block heater was suppose to have been installed (I may be wrong on location) and found this plug.......Does this look like a good spot for the send in unit where I am pointing ??
Drivers side rear of the motor, above the oil pan...Just to the right for reference is the oil filter you can start to see..
PropDr
Eugene, Oregon
Well, not knowing the configuration of the block it could be oil or water.
If no one else knows, there is only one way to find out: loosen it.
Also, if you know the stroke length, the water jacked has to be within that range.
