Vision x or rigid
McDowell
Oklahoma
I was looking at getting some fog lights and maybe some hood mounted lights and can't decide between vision x style or the rigid style lights. What are your thoughts and pros/cons on each guys?
Sent from my iPhone
AlternativeOffroad
Los Angeles, CA
There's pros and cons of both. Personally, put Light Cannons on the hood. It's a bigger better light for hood mounts. Then my opinion is put D2's in the fog areas. That will give you optimal light setup. You'll get distance from the Cannons and up-close and Driving light from the D2's in the fogs..
Krab
Central Texas
^^^ This.
I love my rigid lights (D2's and 20" bar), no problems with them whatsoever. I am in the process of adding a pair of hood mounted 4.5" VisionX light cannons. Can't wait to get these puppies so I can install them.
RSiWORKS
S.C.S. Michigan
Have you looked into KC's fog light kit?
SYSTEM INCLUDES (4) KC CUBE LED LIGHTS, (2) MOUNTING BRACKETS, (1) COMPLETE WIRING HARNESS
Fits 2010 - 2013 Ford Raptor
2,600 Lumens Per Light / 20w Each
Driving Beam Pattern
Easy Bolt-on Mounting Brackets to Factory Locations (No Cut / No Drill)
Included Wiring Harness works with Factory Up-fitter Switches
LED Life-Span: 50,000 hours
for a total of 10,400 lumens
PM if you'd like a price.
McDowell
McDowell
Oklahoma
Can I put all of these on one switch?
Sent from my iPhone
Krab
Central Texas
If they're 20w each, that should be right under 7 amps, so you should be able to run all 4 on switch 3.
BearLeeAsian
Dallas Texas
Just got dual 30" Epic lights - same components as rigid (so I'm told). Will post night shots later. Picked them up at a local shop here in Denton. $600 installed each.
93,224
56,503
DehydratedSurfer
Latest posts
