GEN 2 Upgrade Exhaust Manifold Set with Turbo Adapters
Wainwrcb
Royal Oak, MI
Any you guys running upgraded full bore exhaust manifolds (e.g. CR Performance) and high turbo exhaust adapters (e.g. SPD Performance or AMS Performance)? I’m curious to here about combined results.
Guy
It makes sense
improve the efficiency of the pump. Less restrictive intercooler, AMS Intake tubes, manifolds, larger higher flowing turbos, large open turbo flanges, higher flowing downpipes.
That’s the setup... if you’re going as far as the turbos.... it’s not much more to add the other components. Then with a proper tune, you’ll see quite a bit of performance.
the one caveat here is the cat back exhaust. I would run stock because the noise becomes unbearable.... even though there probably is a handful of horsepower left on the table... it isn’t worth it.
93,180
56,460
khunter
