Highroller60
Hello All,
I have a 2010 Raptor 5.4 that I purchased new. It has 116,000 miles on it. Yesterday when out to go to the store and noticed a 12" wet spot on the concrete under my truck. After further inspection I found a drip of what smells like tranny fluid on the lower bolt, that connects the tranny to the transfer case. I put a socket on the bolts and found the lowers where not loose but not exactly very tight either. I tweaked them about an 1/8 to a 1/4" turn. I then cleaned the area with brake cleaner, too let me know if it continues to leak, after I drive it a few miles, so far so good, doesn't look to be leaking. But it makes me think the output shaft transmission seal or input shaft seal of the transfer case maybe be bad. Should the coupling between the tranny and transfer case have fluid in this area?
Thanks
Highroller60
Thanks
Highroller60
