SVC Bump stop bracket install interfering with exhaust mount
toeknee
Polson, MT
Has anyone ran into this? When I go to install the bump stop bracket on the passenger side, the bottom of the bracket covers the bottom hole for the exhaust mount. I see in SVC's video that they say to remove the two bolts to make install easier but they never say what to do with them.
Should I drill a hole through the bottom of the SVC bracket to put the bolt through for the exhaust mount?
Ryan C
Vancouver, Canada
I had that same issue. I can't understand how they make these like this, and don't offer any sort of explanation. Anyways, I cut the exhaust bracket so it would clear the bump stop. The bracket is now only held on by one bolt, but I cut off the exhaust right after the hanger so figured it would be OK like that.IMG_3344.jpgIMG_3346.jpg
toeknee
toeknee
Polson, MT
Jeff @svc got back with me and said "That hanger is removed. Some will trim the hanger, we just eliminate it."
Thanks for posting your solution, that's what I figured I would do. Finished one side yesterday, going back out to complete the install today and I am going to do exactly what you did. Even without the hanger on, the exhaust doest move at all. But I figure the hanger with one bolt is better than nothing.
May I ask why you cut off the exhaust after the hangers? Clearance?
Ryan C
Vancouver, Canada
Yes for added clearance. I also plan on getting a rear bumper eventually so figured I would just cut the exhaust sooner than later.
