Sunroof leaking
McDowell
Oklahoma
Just went through the car wash and my sunroof is leaking I'm pissed the truck has 10k miles on it! Anyone else have this problem. e8y4y7e4.jpg4abugepe.jpgu5upama8.jpg
Sent from my iPhone
Teej119
OKC
you aren't the first, I believe I saw a fix thread on here for it on here somewhere.
dfelicia
CT
Sent from my iPhone
Warranty fix. Get in quick and make them dry everything out for you before it has a chance to get moldy. I had a VW with water ingress issues from the start and it was a BITCH. Damn thing leaked for 10 yrs regardless of how many "fixes" the stealership made... truth was that they couldn't find the leak. Mold and stench. Yuck. At least you know where your leak is. (Check that the drain plugs around the sunroof aren't clogged with debris. Blow with compressed air to be sure.)
SVT N8
Harpers Ferry, WV
I've had this problem way too many times with all makes and models. I avoid sunroofs at all cost. As mentioned though, make sure they do a thorough job to prevent any possibility of mold and rot.
McDowell
McDowell
Oklahoma
Noted sir
Sent from my iPhone
tretopflir
its why i ordered with out....my 07 expedition has it..only used once....
McDowell
McDowell
Oklahoma
One of the drain plugs weren't installed correctly and my sunroof sat too low apparently
Sent from my iPhone
