SCT X3 Tuner - Rejected Smog
Discussion in 'Ford Raptor Problems and Questions Forum' started by Pynenut, Jul 24, 2014.
  1. Pynenut
    Pynenut Full Access Member
    46
    701
    148
    Jul 5, 2012
    Las Vegas, NV
    Just took my Raptor in to get a Smog check here in Nevada and received a "Rejected Smog" result. Looks like it failed on the OBD Catalyst, Oxygen Sensor.
    The tech asked if I had disconnected the battery. I had not but did install the 93 tune although it has been a few weeks. He told me to return it to stock and run it for 50 miles and bring it back.
    Just wondering if anyone else here had a similar issue? Was it due to the tune? Did returning it back to stock allow it to pass?
  2. Westside Offroad Group
    Westside Offroad Group Supporting Vendor Supporting Vendor
    2,587
    2,212
    Apr 8, 2012
    Westside
    could be an oxygen sensor
  3. NickPic83
    NickPic83 FRF Addict
    35
    9,641
    2,432
    Jan 31, 2012
    Rockland County NY
    its possible all your sensors havent had enough time and cycles to "ready". everytime u flash/tune your truck all sensors reset and need miles and cycles to "ready"
    how many miles have u put on it since the last time u flashed it?
  4. Pynenut
    46
    701
    148
    Jul 5, 2012
    Las Vegas, NV
    Couldn't say for sure but it was about a month ago, so probably at least 500 miles which seems like it's enough for a cycle.
    The only other thing I can think of is I put on a MBRP turndown and removed it in 2 days. So it was on, then off, not sure if this would affect it.
    I just returned it to stock tune and plan on putting 50-60 miles on it and bring it back for a retest.
  5. TheJoker
    TheJoker FRF Addict
    52
    4,126
    3,288
    Dec 6, 2010
    N. E. Massachusetts
    This happened to me. I was running a 5 Star tune and most sensor came back as "not ready", REJECTED. I returned it to stock, drove her 100 miles, and everything checked out fine.
  6. Pynenut
    46
    701
    148
    Jul 5, 2012
    Las Vegas, NV
    Thanks good to hear! Hopefully everything will check out. This gives me a reason for a trip up the mountain tomorrow!
  7. TheJoker
    TheJoker FRF Addict
    52
    4,126
    3,288
    Dec 6, 2010
    N. E. Massachusetts
    This is from my failed inspection:
    Pynenut likes this.
  8. Pynenut
    46
    701
    148
    Jul 5, 2012
    Las Vegas, NV
    [​IMG]
    Here are my results. We'll know for sure if the culprit is the tune or not soon enough.
  9. SilentShooter
    SilentShooter FRF Addict
    3,055
    1,962
    Dec 29, 2013
    Siesta Key, FL
    Pretty sure the tune turns off monitoring of the rear as a default so they don't have to deal with it on LT and off road pipe trucks. Will cause it to fail every time. Just run stock for a while and retest and you will be fine
  10. Pynenut
    46
    701
    148
    Jul 5, 2012
    Las Vegas, NV
    That was it! Never been so happy to pay $714 for registration before.
Share This Page
