We have a Triple Fog Light Kit with Baja Designs and Rigid Industries lights available. Check it out here:
https://www.4x4truckleds.com/vehicl...2017-2018-f-150-raptor/triple-fog-light-kits/
The Rigid D-Series Kit would be here:
https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-d-series/
We make our own brackets for the Raptor/Lighting Kit right here on Long Island out of stainless steel (powder coated as well). So you'll get the best brackets available on the market from us with the most adjustments. Plus, we also offer a Raptor Lifetime Guarantee on our brackets.
As for amperage, it all depends on which D-Series you go with. I'd HIGHLY recommend you keep all 3 pairs on 3 different upfitters so you have full control. Our kits include our own harness that makes installation easy (ALMOST plug and play).
If you wanted to put 2 pairs on 1 switch, you sure could do that as well.
Switches 1-2 are rated at 15Amps
Switches 3-4 are rated at 10Amps
Switches 5-6 are rated at 5Amps
Here is our guideline (included with the instructions) for figuring out your amperage:
Baja Designs S1 (Pair): 2.9 Amps Max
Baja Designs S2 Sport (Pair): 1.8 Amps Max
Baja Designs S2 Pro (Pair): 3.32 Amps Max
Baja Designs Squadron Sport (Pair): 4.0 Amps Max
Baja Designs Squadron Pro (Pair): 6.66 Amps Max
Rigid Industries D‐Series Driving (Pair): 6.28 Amps Max
Rigid Industries D‐Series SAE (Pair): 3.0 Amps Max
Rigid Industries D‐Series (All Others, Pair): 4.28 Amps Max
Rigid Industries Radiance Pod (Pairs): 2.0 Amps Max
Rigid Industries Radiance Scene (Pairs): 4.0 Amps Max
So 2 pairs of Driving would be 12.56Amps. Which you could do with Switches 1-2. As for the Floods, those would be 4.28Amps max so I'd stick with any switch from 1-4. You COULD use 5-6 BUT you may blow them from time to time as it's close to their max. You want a little wiggle room. You still have .72amps of wiggle room which might be good though.
As to the amber/white question. No they don't have the same lumen
Driving White have 4752 raw lumen
Driving Amber have 1760 raw lumen
Also use coupon code FOGS at checkout and you'll save some cash right now on our Triple Fog Light Kits.
Check out our youtube video as well which really demonstrates our brackets:
