recon truck lights HIDS
NY SCREW
new york
recon is garbage and have done little to improve what is a lack luster product...they are at most eye candy with zero functionality .....hit up Dawsons ducati retrofits you will get an eye ****** to your liking an blinding light that will not let you down
Alrights so about a week ago i purchased recon projector headlights. They weren't as bright as I was hoping so i called recon and purchased some HIDS for my headlights. When i got them in the mail there was only low beam bulbes. Shouldnt you get low and high beam bulbs? As yall can tell in know nothing about HIDS. Please help me out!
The HID kit will go in the low beam only, which is the projector portion of the headlight. If you have any install questions please give us a call and we can walk you through the install.
I am sure you will love the output of the lights once installed and will not think of the product as 'garbage' as a few other posters suggested.
Best,
Ryan
Netix
Banned
Ontario, Canada
Well I've been waiting for a month to get any response to my emails to reconvene about 2 faulty headlights that constantly leak inside. I've been pulled over because of them. The inside of the housing is caked up with mud. That should definitely be replaced by warranty
Sent from my SGH-I717R using Tapatalk 2
claustin
North Dakota
Ok. I think something's getting lost in the translation here. I'll try to explain, but I'm going off of my experience with Recon lights for a 2011 Toyota Tundra.
The Recon lights may or may not use your stock bulbs. I'm not sure. I seem to remember when I bought mine they came with the single set of H1's for the high beams, and I was able to plug in my existing low beams into the projectors, OR since I bought a HID kit with them, I could use the HID kit for my lows. I don't remember for sure. It may have been that I had to go buy an extra set of H1's for the lows until I put in my HIDs. I highly doubt they use the stock bulbs though, because they are a single bulb for the highs/lows. This is all besides the point though, because you said you ordered a HID kit from Recon. SO, what you do is hook up the HIDs and plug them into the low beam projectors, and use the H1 bulbs in the high beams.
Now that I think about it, the ones I got were Spyder brand, but I believe the process is more or less the same for all of them. The Spyder's sucked btw. I gave that truck to my dad and 3 of the 5 LED's on the passenger side burned out already.
If I'm way off, somebody, probably Ryan or somebody else from Recon, please help the guy out.
