GEN 1 Rear OEM Shock removal
Raptor911
Ashburn, VA
I apologize for the dumb question but I need to remove the rear shocks.
Can I just remove the rear shocks without jacking up the frame? Once removed, can I just leave the truck without shocks and NOT drive it? I need to send the rears for a rebuild and then I will reinstall the rear shocks once I get it back. Again, I will not drive the truck until the rears come back rebuilt.
Deleted member 12951
Guest
Rear Shocks have been known to get stolen right out of people’s driveway. So yes it can be done.
I would recommend jacking it up to take off some tension from the shock bolts but yes it can sit without shocks. I had mine sitting for almost a month waiting on rebuilds.
CarmanKyle
Pasco, WA
I would say jack it up and pull them. Unless there is 0 nitrogen left, trying to pull them while theyre compress is tough. Not saying it cant be done, but its tough. Youll need a pry bar and a mallet at a minimum. Installing them, youll need a jack
Raptor911
Raptor911
Ashburn, VA
I have a jack (actually I have 2 floor jacks) but I don't think I can jack the frame high enough to get a full droop of the rear suspension.
CarmanKyle
Pasco, WA
Jack rear at diff, pull wheels, lower completely, then use your other jack. Thatll get you a few more inches
Raptor911
Raptor911
Ashburn, VA
Actually, I think I can do this:
- lift the diff as high as possible with the floor jack
- then support either side of the frame with jack stands
- then lower the diff and the rear suspension should droop some, I hope
BenBB
Lots of different places
That's what I did, although I pulled the rear tires on the way up with the first step, and the old floor jack needed a 4x4 block on top of it. Once the frame is on jack stands and the wheels are off you should be able to droop all the way out easily.
BTW going back in you may need a hefty friend to push down on the axle or use a small bottle jack between the axle and frame to get the new shocks in.
