GEN 1 Rear Door Lock Issue
Jhollowell
Everett, wa
I've been having an interment issue with my passenger side rear door lock sticking. Every once and a while only that door won't unlock using the power buttons but if i pull on it, it'll unlock and then work smoothly. It takes quite a bit of force to unlock it, but once its unlocked it cycles with no issues. It seems to be random when it decides to stick and I can't inspect the mechanism when it does stick because the door is closed and the panel is on. if i unlock it by hand and pull the panel, everything is working as it should so i can't see whats causing it to stick. I guess i could just pull the door panel off or a few days and wait for it to stick and see if i can see what the issue is, but i think it'll still be tough to examine the mechanism with the door closed. Anyone have this issue and find what was causing it?
Dane
Littleton, CO
It's your door actuator. I've had to replace two, and it looks like one more is occasionally doing it now. It's not a tough job to pull off in your driveway, but it's definitely the door actuator. My only door that hasn't done this is my driver door.
93,273
56,557
oRoarke
