dangCrank shaft is much stronger in Ford GT.....
they do not share "lots of parts".
sorry to burst yall's bubble.
you're not getting the same motor that comes in a 500K+ supercar in your 65K pickup truck.
I wonder how hard it would be to swap some of those parts over to our Raptor.The engine architecture is identical; all of the parts are interchangeable and 60% of the parts are shared between the Raptor 3.5 HO and GT. . They even share the same fuel system, right down to the part numbers for the High Pressure Fuel Pump, Direct Injectors, fuel rails, and Port injectors. Same goes for the valve covers, ignition coils, spark plugs, cam sprockets, etc; all the same.
The GT differences are application specific, such as the dry sump oil system to support high G track use, revised camshaft profiles and larger intake manifold to support higher RPM, and a lowered compression ratio of 9:1 to support increased boost from the larger turbos.
Sooooo do they share the same cam phasers? Lol
It doesn’t sound too hard to mimic cams, turbos and lower compression turbos...I wonder how hard it would be to swap some of those parts over to our Raptor.
When I finally build the engine in my 19 Raptor I'm going with a Dailey Engineering dry sump setup just because lol. Gonna be a few years but it will be fun.
The issue is that they mark up the parts to discourage installing them on non-GT vehicles. For example, the retail price of the intake manifold is $5338 and the camshafts are $2619 each.
It’ll be like what it is tuned just faster but there are guys running around w/ GT level power & then some already on this forum- most got hardcore tune + E85/**** conversion & most also have upgraded turbos, seems like some have punched out the blockI'll take 3 of each.
I'd like to get a ride in a raptor that has the full GT spec setup, just to see what it's like.
