Raptor Auxilary Trailer Power
Mxsledder
Utah
Hey guys, I just bought a small new enclosed trailer with an electric jack and interior lighting. The raptor runs all of the exterior trailer lights perfect but it will not power the electric jack or turn on the interior lights.
Any idea what maybe causing this? Dealer is pretty lost. I’ve heard maybe the truck needs some fuses that are not installed from the factory?
stolleee
Memphis TN
I am not aware of it having that feature. It doesnt even have an outlet of power in the bed area. I had to run a line from under the hood all the way to the rear to be able to have access to power
NE Raptor
Massachusetts
My enclosed trailer will run the interior lights as long as the truck is running or in ACC position. I believe you should have a main junction block on your trailer and to run the jack I think you would need to run a battery to that - at least that is how mine is set up.
jabroni619
Are you sure the trailer is actually wired to pull power from the 7 pin for those accessories?
richnot
Central New Jersey
Have you talked with the trailer manufacturer? Maybe they can give you some insight with hooking it up to a Raptor.
Does anyone know if the Raptor 7 pin is any different than a regular F150?
Nice setup you have!
JP77
Alabama
The truck has to be powered up... as in running or the lights on to put power to the trailer. I found The lights on the truck need to be on not on auto to push power through the 7 pin. You can add a battery and charger to the trailer if you need power while the truck isn’t running.
93,180
56,460
khunter
