Painted Exhaust Tips
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by danmpe, Sep 20, 2010.
  1. danmpe
    danmpe Full Access Member
    111
    Sep 14, 2010
    Ephrata, Pa
    I painted the exhaust tips black.
  2. BIRDMAN
    BIRDMAN Birdministrator Staff Member Admin
    12,923
    6,142
    May 16, 2010
    Boston
    i've been thinking about this myself. the big honkin silver pipes hanging out the back certainly catch your eye on an all black truck. hell i even painted my EZ Pass highway transponder black cause I hated the way it looked white in the middle of my windshield.
  3. danmpe
    111
    Sep 14, 2010
    Ephrata, Pa
    As per the EZ Pass there is a bumper mount that is black. I have one on my truck.
  4. BIRDMAN
    12,923
    6,142
    May 16, 2010
    Boston
    oh nice i didn't even realize they made those. i just painted it black and tucked it way up high behind that "F-150" eyebrow on the windshield. It's basically invisible.
  5. pirate air
    pirate air will plunder your booty Supporting Member
    4,254
    1,344
    Jul 11, 2010
    Looks good. I cut my tips back about three inches and I think they look better, but painting them black is still on my to do list.
    x2, Ford could've spent more time on the tips. Instead they continue to make their truck tips look like objects you would find in the pluming department at Home Depot.
  6. danmpe
    111
    Sep 14, 2010
    Ephrata, Pa
    You know them engineers. They are the ones with the big brains and the little pencils.
  7. BIRDMAN
    12,923
    6,142
    May 16, 2010
    Boston
    i'm all about showing off big exhaust pipes but the stock ones are a bit utilitarian for my taste. now some 4" side exits i would have no problem let them hang out and catch the eye.
  8. warrior
    warrior Your Wife's Personal Trainer
    788
    105
    Aug 19, 2010
    curious to see if the paint sticks, have painted my Dodge pipe more than once as the paint seems to burn off.
  9. BIRDMAN
    12,923
    6,142
    May 16, 2010
    Boston
    If i was gonna do it I would clean the hell out of the pipe with steel wool and degreaser to remove road grime and lightly scuff the surface. then use the High Heat primer, then the High Heat black. All coats mist coats...not much will take it off.
  10. danmpe
    111
    Sep 14, 2010
    Ephrata, Pa
    I cleaned the tips with acetone before I painted them. Be sure to cover and tape over areas that you don't want the overspray to hit.:birgits_tiredcoffee
Share This Page
