OEM Hood Graphic Pictures
cayenne
Windsor, CO
Would someone mind taking a couple pictures of their OEM hood stripes and post them? Especially interested in the rear alignment and fit. I'm going to be installing mine, but I haven't been able to find good overhead pictures showing placement.
kandewinn
Found this on the INTERWEBS
nikhsub1
Los Angeles
Damn I'm not around for a week or so, I installed mine myself with no help. If you don't have rapidtac, get some before you install... it makes the install sure easy. also, there is a guide on the paper of the decals of how to align...
cayenne
cayenne
Windsor, CO
Thanks. I hadn't even opened up the box so I didn't realize they had a guide. I've always just used a water/soap solution and never had issues. You find Rapid Tac that much better?
nikhsub1
Los Angeles
Water/soap should work just as well... what I should have said was use a liquid solution... Yeah take the decals out of the box - If you align each one to the inner curved ridge that runs down the hood, it's pretty self explanatory. I did find a top down image but I had to zoom in so it isnt super clear but It's all I got while being away, maybe it will help...
3x3ROpv62UapIbnhUrFPYImII-aahwlpzrVwt0UWOqH0lKJYXDCe6M4aN_u-Hy0aneUFNptJKpN_Ea-A6sDVTDPEYyRmKOwwrpphJL9zECPAms70UZddO6XKwU4WYAV4sp52WNx3yAunQwILK0YAMQysQuAsddyMGZ0OjCmukIS8McYcdI_HYHOklSRM1e5tsG5hqj5x_70r18DqmzZ4oOAWs5iTtDERXfK2svlqHITzov_PusNcDbhwDJPNkZLMB_MmK97KQcwV0oThuvq88jrMvk2MO0IY-MFfIn89kLbScl_vzSWV4x4usZcGdtNU6GF3o6uZ1IMNiuWTz2LsJA0m8nyiYg0vWRE0-CbYZvGcA6XC67uwdVBPLa_JwzUTf9E9BytnLCpEaZ7pnUBYiuEYit5WlY1FTOHVd7um2-dzHzrAaGoRjYeQLNDc5WqhT8p9lzkPHThdEBl7Z3hIgn9jFVEXrKf19SZzuEYHpGdU--G8YswSqDRQieHoZ5Q7_52EUy0u_nHTWsCqi6Jx6qahlV6eHcH60MvwC41KEXTGVSMYOfT1gr2ou1z0YtnCe9Ay5g5RzusVM7s9gqNNV5eF880eDQpSLlb80bZC=w1832-h1490-no
rgrismer
CT
Race Red
IMG_20171130_144820890_HDR.jpgThis truck is an animal. It tunes up the horsepower when you drive aggressively. It gets really angry when it can't get enough traction. The tires really perform, they can spray dirt a couple hundred feet, stay clear of the back.IMG_20171130_144830921_HDR.jpg
